Official HPI Savage Flux XS thread...
#1751
RE: Official HPI Savage Flux XS thread...
For the jeep body you can try here:
http://www.hobbyetc.com/catalog2.cgi...at=all&man=hpi
http://www.rcplanet.com/SearchResult...&Submit=Search
#1752
heres a few short vids of mine at my local skate park,crappy windy day but still fun
http://www.youtube.com/watch?v=gMRaa...&feature=g-upl
http://www.youtube.com/watch?v=Pvfjh...&feature=g-upl
http://www.youtube.com/watch?v=wKON7...&feature=g-upl
#1755
after my share of problems i have been running my xs a lot lately. i have replaced the esc with a vxl and the motor with a 2 pole tacon 4000kv. also upgraded the steering servo. it runs great and i love the little truck. i run in my yard mostly which is all grass. im having trouble keeping the motor temp down. i have went from the 28t pinion all the way to a 23t. i run it on a 3s 5000mah 30c/60c lipo but im not a full throttle driver and don't drive it real hard. any one else having this problem? is my gearing still off for just bashing and running in the yard? is there something else i can do to keep the temp down? thanks, matt
#1757
first time out i hit 180 real quick. before i even knew it, that was with the 28t. i dropped a couple teeth and it took longer to get hot and i stopped when it hit 170. i dropped down to 23t and run it today and got the longest run time before i hit 160 then stopped. i normally run my motors around 150.
#1758
ON, CANADA
ORIGINAL: dms888
I run a castle SCT 3800 motor with stock gearing and temperatures have never been a problem on 3s/65-130C/4300mAh battery. I quit following temperatures a while ago since it was a waste of time because the temps were beyond safe. I am happy with the gearing and don't plan to change it and there is more room left for taller gearing.
#1759
My Feedback: (9)
ON, CANADA
In my experience those tacon motors tend to run warm, probably cheaper magnets. Combine that with running on grass and the temps are going to go up.
#1761
ORIGINAL: nitro-rob
I picked up a blur ESC for $115 shipped off of ebay last night. I can get a mamba max pro for the same price. I would prefer to run a mamba max pro in my blitz for the track and may have to pull the one from my XS in the meantime.
I sold my unused vapor pro and vektor 4000 from the XS for $115.
The XS has inspired me to eventually get an HP. I thought about converting my savage but it needs too much including differentials. I think its better to buy a flux 2350, take the ESC out for 1/10 since I need one and put the blur in there and eventually change the motor ( I do have the HP motor in my truggy). I can keep my nitro and move my mods over to the flux eventually (then sell my last nitro?!).
Thats what I did, got the Flux 2350, bought the HP motor for $140, took the 2350 motor out and put it in my 1/8 onroader, and I use HK 120A 1/8 Brushless ESC's over MMM's anyway, so $50 for the speedie and the Q Base thing is on 1/10 Corr duty in a Nexx 10SC
#1762
My Feedback: (96)
OH
ORIGINAL: dms888
any idea of what a safe temp is i can run this motor at without frying it?
matt
matt
#1764
ORIGINAL: dms888
#1765
Hi Rob,
Here we are:
Here we are:
ORIGINAL: nitro-rob
#1766
ORIGINAL: t9dragon
One of the issues that could be causing your high temps is that you are running it in the grass.
ORIGINAL: dms888
matt
#1767
OH
Thanks nitro-rob for showing us how to pull the transmission almost painlessly.
Now to fire up the soldering iron to heat the bajeezus out of the rear outdrive so the MFer will come off the MFing shaft[:@]
#1768
can anyone link me to the shims they are useing to shim the diffs?Also i have heard that its a good idea to shim the rear lower suspension arms?Thanks for any info.
#1770
ORIGINAL: ThunderbirdJunkie
The shims are already there. Just take one from the cup side and put it on the ring gear side.
#1772
MN
I'm thinking about getting one of these machines, what breaks first usually?? And what mods should I get off the bat? Also will my lipos fit, I got 2 sky lipo 2s 4000mah 20c hardcase, and a 3s 4000mah 20c sky lipo hardcase
#1773
ORIGINAL: rc theman
#1774
from my experience with this truck i have to recommend you not use a 20c lipo in it. these trucks pull alot of current and i dont think 20c will hold up. also you can expect the esc to go up in smoke if you connect a 3s battery. i ended up replacing the esc, motor and steering servo. great truck not so great electronics.
matt
matt
ORIGINAL: rc theman
#1775
ON, CANADA
I don't think its a rule that 3s blows the ESCs, there have been a bunch of failures but I am not certain if it directly correlates with 3s running. Many are running 3s just fine.
