xmods vs miniz
#401
RE: xmods vs miniz
ORIGINAL: Cheezman
I used to like Xmods more than MiniZ's, but now that I have really been using a friends MiniZ, I really am interested in getting an MA01...
#402
RE: xmods vs miniz
ORIGINAL: Tigger N. Bennie
Some people have installed either Kyosho or Iwaver electronics in the older models. I'm unsure about the Evo, but it the fix would probably be the same.
ORIGINAL: RS4rallydriver
is there ANY WAY POSSIBLE to use a futaba ms radio with the car? I really like the new evo, but I really want a better radio.
As for me getting an MA01... I'm getting one for sure, I don't know when, but its about time my Xmods meet their master (or something like that.. LOL), I like those bodies (yes, I have seen quite a few, my brothers friends have MR01's and MR02's), but I happen to like the White V-Spec II the best... ROFL, it happened to be my exact favorite car (including color), besides the WRX STi. The real turning point for me, was when my brothers friend let me use his MR02 (for a long time LOL), That with AWD will be a freaking beast!
#403
NY
RE: xmods vs miniz
what was it you said about the servo? when I took my evo apart ( to install the ball bearings) I noticed that it doesn't really have a regular servo; it has a motor wired to the all-in-one board that works as the servo. are the nini-z's and iwaver's steering designed the same way?
also, are the electronics a direct fit? I REALLY WANT TO USE A BETTER RADIO! If it isn't too hard, and it wouldn't harm performance then I would switch it as soon as I could if it meant using my futaba radio.
#405
RE: xmods vs miniz
As for the MiniZ/Iwaver Servo being the same, Couldn't tell you, but they gatta work along the same lines to be adaptable to each other.
#408
RE: xmods vs miniz
u talk some ****tttttttttttttttttttttt i bet your a 25-35 year old man that sit all day and plats with his little toy carrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrssssssss ssssssssssssssssssssssssssssssssssssss[>:][>:]
#409
RE: xmods vs miniz
hi will i just got a newxmod and bought a lithium batts kit could some one tell me how to put it on and what are fet's and what do they do ???????????
#410
NY
RE: xmods vs miniz
I dont know what lipo kit you got so I can't help you there. FET's allow your car to safely handle higher battery voltage and hotter motors.
if you were to try to install a really powerful motor and/or more cells without stronger FET's you would likely overload your electronics... (like I did with my first car). wwwatomicmods.com has a whole lot of lipo kits and FET chip information.
#411
RE: xmods vs miniz
I also want to advise you, be very careful with Li-Polys, they are far more touchy than Li-Ions.
#413
RE: xmods vs miniz
ORIGINAL: xmod master
i have an xmod and could any one tell me do u need 4wd to use the tamiya speed checker
#414
NY
RE: xmods vs miniz
ORIGINAL: Cheezman
Fet's are a need, not an option, they don't "allow", they "make". They are what make your car go forward and reverse, and allow your servo to move. Also FETs have NOTHING to do with batteries voltage, you have a diode on your ESC which handles the voltage, your FET's just drive off what you give them.
I know that... and I know what they are for. I thought he specifically meant UPGRADED fet's. so I just said why people upgrade them. and I have read that it is recomended to upgrade them if you plan to run more voltage through your car's electronics. (which is usually the case when you use lipo cells). I don't want to mess with lipo cells just yet, they are too touchy. I crash too much!
vvrrrrrr-bang, vvrrr, vaaaaa-bang, vvrrrrrrrrrrrrr- oh no the stairs!...booom, crash, snap...awww man!
#417
NY
RE: xmods vs miniz
I think that it can do something around 18 m.p.h. I have to check to be sure... if the car still has the nylon bushings, then it will be slower. but it should be good with bearings.
#418
RE: xmods vs miniz
#420
RE: xmods vs miniz
stock cars are meant to be upgraded. I am just waiting for atomicmods.com to get aluminum suspension and driveline parts.
#421
RE: xmods vs miniz
will i got 900mah ni-mh batt and my xmod is stock only for a stage 2 top speed motor is the to much (900mah) for a stock xmod or is it good and wood it make it any faster?????
#422
RE: xmods vs miniz
#424
RE: xmods vs miniz
ok thanks will it make it faster in any way ???
