Official Mini-T Thread
#2552
NY
RE: Official Mini-T Thread
If you can fit the seventh cell then go for it. The 8.4 will be fine with the stock electronics because there are people that are running 11.1v Lipo's with the stock electronics with no problems.
#2553
FL
hehe il make em fit, and since you say that il get as much power as i can put in there and charge(dont want to get a new charger for li-po's)
#2554
IL
I have a heat issue with my Mini-Baja. I'm using a Reedy Mini Mod 17 turn motor on a stock ESC, an IB 1400 and dirt hawgs. I am running an 12 tooth pinion. I was going to use my lowest, 11 tooth, but it was an Ebay buy and it has a set screw stripped inside it. I don't think 1 tooth would be good enough maybe 2 and a bigger spur, and the spur is stock. Should I get a heat sink motor plate or try getting a bigger spur and/or a smaller pinion?
Pontiac K
#2556
FL
So I've been thinking about a new motor for my mini t and i was reading the earlier posts for some guidance i read allot about a k3 or something like that i don't want to spend to much on it so...is the k3 good or is there something better and where do i buy it?
#2560
AHHHHHHHHH My baja ariived today. Now I have a question how do you get that stock plastic pinion gear off? The motor is acting up and I want to take the springs and brushes out to make sure there not the problem but I cant get that d&*n pinion off.
Hey frank I bought my nephews minit's for christmas and one was purchased off somone that didnt have a motor so I had to buy one. I bought the mini moster for I think $38 and it was definitely and upgrade from the stock motor. I heard the baja was a better motor but from the short time I had it going it was pretty nice. Thats also with a new battery thats only been charged once so a battery that has been cycled a couple of times would make this car go. I also saw a little difference in speed when I got my nephews the bearing for the wheels, if you dont already have them.
#2562
FL
GRATS on getting your Baja and i already had in mind getting the bearings as one of my first hop-ups. as for the motor Im still looking around but i believe Im going to order one soon when i order another motor but for my pede(i somehow fried it)
#2565
I ran the baja for about 2 months till I was bashing on my road and I shattered a magnet. I'm going to either sell my Mini-T for a new Vendetta ST or go BL/Li-Po.
#2569
WV
I ran the baja motor in my mini t when i used to race it. It is a good motor and it lasts along time. I also have a brand new set of brushes for it that i have not put in it yet. Plus i made it to where i can adjust the timing on the baja motor. I used to put the 17t pinion on it when i would run it on pavement with the losi foam tires and it would really go. I got rid of my mini t last year but i kept the baja motor. I figured i would keep ahold of it just incase i get another 18th scale electric car. When i used to race with it i would use the 9,10,11,12t pinions. But mostly the 11t for the track that i raced at. I would advise people to get the baja motor. It really is a strong motor and lasts along time if taken care of. Oh, and i never used the plastic pinion because it would never stay on once the motor got warm. I even tried to use CA but it would not stay on and would come off.
#2571
To take care ofthe motor would be:
1. Running at the spec voltage..
2. Not over gearing the motor..
3. Runnng at the right temps and not running two packs back to back if the moto is warm..
Thats just a couple,
Andrew
Andrew
#2572
replace brushes when needed, use trinity royal oil, just a drop or two on the front bearing where the motor shaft is every month or so
#2573
FL
When you guys say the Baja motor which one do you mean, the one that comes with the baja or one called the baja, or a totaly different one. A link would be greatly appreciated
#2575
