Official Mini-T Thread
#2526
RE: Official Mini-T Thread
Yea your gonna need to up grade the shocks major! Really high wieght oil and the stiffest springs out there and I doudt that will even do the trick. Then all this added weights gonna make i heavy and hard to control around corners and the jumps will be extremly bad... When I had my full aluminum mini t:
When I used to junp that it only went about 1/2 the distance it did when it was plastic wuth bl..
Andrew
Andrew
#2529
I'm getting out of 1/10 for a while and I plan on getting my Mini-T and a new Vendetta ST. People running BL are you having problems stripping your rims. When I ran my Baja and Elite 1500 I broke the inside of the rim where the pin went?
#2531
I had that happen once with my 6800kv the pin in the inside of the rim stripped, but thats because I had a locked diff, I then went to a ball diff and never had a problem at all
#2533
Can anyone tell me the difference between the mini t and mini baja? I just one a mini baja off of ebay and all I can find is that it has bearing and the esc and reciever are seperate. are there any other differences because thats not really worth the extra 50 they get in stores.
Also what upgrades should be made first? Im ordering 2 sidewinders esc's with a 6800kv motor. ( I have 2 4200kv motors from when CC website had them for 20 so Ill prob put one in the baja first)
thanks
thanks
#2534
its deff worth the extra 50 dollars, the orignal mini-t its has an esc /reciever in one, no bearings and a junk radio, with the baja when you do go brushless you can use the reciever and same radio, and it comes with bearings, deff is worth the extra 50
#2538
The Mini-Baja has oil shocks stock but lots of them aren't that good. I would get:
Losi Racing Oil Shocks
MIP Ball Diff
Bulkhead Brace
Elite 1500 or Li-Po/A123
Deftones123 could you post some pictures of the A123 pack in your Mini-T. How does it fit?
MIP Ball Diff
Bulkhead Brace
#2539
Thanks. They sent me a shipping conformation but it said it hasn't been processed yet and since there sending it ups ground I probably wont see it until Mon at the earliest. I wished they used usps I get my stuff in a couple days. Well I need to order stuff for my 18t so I guess Ill add that stuff on.
#2540
frozen I dotn have a digital camera to take pics with, and for me ups is faster then usps, I get stuff from ups in like 2-3 days, usps takes like a week for me
#2541
the a123 pack is alittle big, and by that I mean its alittle thick, it raises the battery hold down alittle, but other then that its fine
#2542
whenever I get something ups ground it always takes exactly 5 days where usps is always 3. I also forgot to ask if they offered other shipping options. Anyway Ill get some pics up when I get everything soted out.
#2543
I try to avoid UPS because most of the time I get my packages the shipping box is damaged and they don't make me sign for it even when it was a 350+ package.
#2544
That to. They left a big box stuck between my door at around 6pm. I dont live in a bad neighborhood but thats not right, atleast give it to my neighbor.
Anyone have a pic of how the ball diff looks in the mini-t.
#2546
IL
I have a heat issue with my Mini-Baja. I'm using a Reedy Mini Mod 17 turn motor on a stock ESC, an IB 1400 and dirt hawgs. I am running an 12 tooth pinion. I was going to use my lowest, 11 tooth, but it was an Ebay buy and it has a set screw stripped inside it. I don't think 1 tooth would be good enough maybe 2 and a bigger spur, and the spur is stock. Should I get a heat sink motor plate or try getting a bigger spur and/or a smaller pinion?
Pontiac K
Pontiac K
#2547
FL
Hello everybody my name is frank i use to be around rcuniverse allot but i got away from the hobby for a couple of years, but now i just got a mini-t and thought you guys might want to see a few pics of it(sorry about the horrible pics phone was dead so i had to plug it in to take the pics) being that this is the mini-t thread. Also as i was running it today and jumping it my right front turnbuckle kept coming off is this a problem with the mini-t's in general or is it special to mine. thanks for the help in advance cause I'm sure i'l have millions of more questions.
#2549
FL
thnx for the tip i'm also going to get a new bat any suggestions cause the batteries that were good back when i was around are probably old and worthless now.
#2550
For Ni-Mh I would get an Elite 1500 pack from www.cheapbatterypacks.com or a 1600 pack from www.maxamps.com. As for Li-Po you would have to ask someone else.
