Official Mini-T Thread
#1726
CA
RE: Official Mini-T Thread
ORIGINAL: LIVipers
Calvino- are you taking about the Diff for the Mini T Tranny or the RC18T. If you are talking about the mini T then heres the link:
http://losi.com/Search/Default.aspx?...%20Ball%20Diff
#1727
NY
Tomcatguy- if you want to get batteries, your best bet would be to check ebay. However 10 min on AA's isn't that bad of run time. The highest MAh packs that you can buy for the stock Mini T chassis is 2600 for Nihm. If you want longer runtime and power then you should try Lipo. Dynamite makes a Lipo battery for the Mini T and it will last you about 20-25 Mins approximetly and you will get alot more power out of it. Sure they are $50 a piece but it will be well worth it because they offer constant voltage and they will last about 3 times longer than compatible Nihm batteries.
#1728
NY
Hey Everyone,
Got my b/l Mini-t up and running now. But after every 2-3 battery packs, my slipper loosens up and i have to tighten it again. Does anyone have any ideas on what i should do to keep the slipper on tight all the time?
N.rustlerfreak
N.rustlerfreak
#1730
NJ
does anyone know of a video of a mini-t with a reedy stump puller sp19 on it? this has nothing to do with it but i run 2300 mA rechargeables and they last forever. and they are no memory so u can charge them whenever. they are like nickle hydroxide or something i dont remember
#1731
NH, NEW ZEALAND
ORIGINAL: N.rustlerfreak
Hey Everyone,
N.rustlerfreak
Hey Everyone,
N.rustlerfreak
#1732
NH, NEW ZEALAND
ORIGINAL: Pontiac K
My shocks keep popping off what can I do to stop them from popping off? Thanks
Pontiac K
Pontiac K
#1733
NH, NEW ZEALAND
ORIGINAL: p3t3v3x53
#1734
ORIGINAL: LIVipers
i found that out on cheapbatterypacks.com but i guess i was wrong, what are the largest size cells that will fit into my stock mini baja?
i have a feeling that i will not like the losi 1100ma pack when the baja arrives.
if i ever find the $$ though i think that a lipo and brushless is in mind
shaun
#1735
NY
ORIGINAL: Damz
Loc-tite is your friend!
Hey Everyone,
N.rustlerfreak
Hey Everyone,
N.rustlerfreak
N.rustlerfreak
#1736
Well is your problem with the slipper coming loose or gear wear? Or both? Loctite is the bsest way to keep your slipper nut in place. Use the blue stuff or you'll have bigger troubles later on. The blue is the removable stuff. Do not be affraid to use it. I have used it on every metal to metal screw.
As far as pinions go the HPI micro RS4 pinions are the best I've found for the price. They work great. I usually grind a tiny little flat spot on my motor shaft for the set screw to go up against. I do not recommend it because most people hog off material but this is what I do. It must be small if you do and quick. Do not overheat the motor shaft. I usea dremel with a sanding drum and just ouch it quick to make the mark.
#1737
NY
ok... will the trinity lite alluminum gears work?(12-16t)? Because i was just wondering. And do i need to do that if i want to fit the micro rs4 alluminums? and yes the problem is both. the slipper comes loose and the pinion already morphed and fell off and thats why i want to get a alluminum one. Anyways... if i do put loctite ill still be able to adjust??
N.rustlerfreak
N.rustlerfreak
#1739
NRF The trinity gears you mentioned I believe are for the larger shafts. I see in their description it says for the KMI and alike. They have a bigger shaft. I would say no they wont work. I know robinson makes a few so does AE and of course HPI. I am sure there are others. Yes you can adjust your slipper with loctite....only the blue stuff. I use this stuff http://www3.towerhobbies.com/cgi-bin...?&I=LXCX59&P=0 It works great.
#1740
IL
I've also asked this in my thread, but it isn't exactly on topic, so sorry to post it twice in two places. My motor won't work unless I turn the brushes on their side and put them in. Will this tear up my motor? Thanks
Pontiac K
Pontiac K
#1741
NY
So the rc18t ones from robinson will work with the mini-t?? and do you know what size pinion the mamba max system comes with, because that's the one that got fried and i liked how that gearing was doing. Please get back to me soon!!!! thanks.
N.rustlerfreak
N.rustlerfreak
#1742
NH, NEW ZEALAND
N.rustlerfreak
N.rustlerfreak
#1745
Pontiac- It will work but it will wear the top and bottom of your com pretty fast. Take your hand and make a "C" and put it around a pop can. Now move your hand straight back off the pop can and turn your hand 90 degrees. Try grabbing the can with your hand inthe same "C". You will notice your finger and thumb are the only part of the "C" touching the can.....just the top and bottom......am I making sense? Your brushes need to be replaced or you need to clean the debris out of the hood or both.
#1746
IL
I can change the brushes, but I couldn't find a way to open the motor up. Thanks
EDIT: Does anyone make a commutator cleaner for minis?
Pontiac K
Pontiac K
