1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Can this charge mini 1/18 7.2v batteries
Old 01-01-2007, 11:53 PM
etphnhmz
Default Can this charge mini 1/18 7.2v batteries
http://www2.towerhobbies.com/cgi-bin...&I=LXXG87&P=ML
Old 01-02-2007, 12:01 AM
guver
My Feedback: (325)
Default RE: Can this charge mini 1/18 7.2v batteries
It can only use the left side (on 1 amp) but may slightly overcharge a nimh battery.
Old 01-02-2007, 12:13 AM
etphnhmz
ok thanks.
Old 01-02-2007, 12:36 AM
Racing T
Racing T's Avatar
no it is complety ajustable, it can charge 2/3 cells without problems, but if you want something nice, cheap, realible and digital take a look at this one, wont make your ride explode lol http://www2.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
Old 01-02-2007, 10:55 AM
guver
My Feedback: (325)
That's a much better choice for mini batts.
Old 01-02-2007, 11:09 AM
tjarr001
how about this charger. [link]http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN4032[/link] i already have it for my e-maxx that i have. also does anyone know anything about this charger it doesnt say that its a peak but the guy at the habby shop said that it is a peak. but when i first got it im pretty sure that it fried on of my 1500 batts for my emaxx and i took the batt back cause i thought that it might have been faulty and they told me that i turned the timer up to much, but that shouldnt matter if its a peak charger right?
Old 01-02-2007, 11:50 AM
Mini_Me
Mini_Me's Avatar
No. It says right on the marketing.
"# 30-minute timer"
If the guy suggested this at the LHS, ask for someone else to help you or find a different HS to support.
Old 01-02-2007, 12:03 PM
tjarr001
when you say no. does that mean it wont charge my 1/18 batts or no its not a peak? i figure that it wasnt a peak. imma go back to that store and tell that guy he needs to figure out what hes talkin bout before he seles me the wrong stuff. if it will charge my bats do you know how long i should set the timer?
Old 01-02-2007, 12:42 PM
fastmax
fastmax's Avatar
It's not a peak charger, and no I would not charge your mini batts on that charger. It has a fixed charge rate of 3.5 amps and it will destroy 2/3a cells very quickly.
Old 01-02-2007, 04:45 PM
Mini_Me
Mini_Me's Avatar
KISS
Keep it Simple St..
This is one of the easiest and cheapest products you can get that works well.
Mini_T Wall Peak Charger
Dont worry about Piranhas and other more advanced chargers until you get more into it.
Old 01-02-2007, 08:01 PM
jombo
jombo's Avatar
get this http://www2.towerhobbies.com/cgi-bin...&I=LXUF45&P=ML
Old 01-02-2007, 08:34 PM
Dokioto
Dokioto's Avatar
That charger is junk! I have had two, (at different times) for charging E-Maxx battery's and they both burnt up...
Old 01-02-2007, 08:36 PM
Dokioto
Dokioto's Avatar
I use this to charge my mini batteries; works well. http://www2.towerhobbies.com/cgi-bin...&I=LXUF46&P=RF
Old 01-02-2007, 08:49 PM
HTMracing
ORIGINAL: Mini_Me
KISS
Keep it Simple St..
will this charger charge the Micro T Battery as well??
Old 01-03-2007, 03:58 AM
metaldog
metaldog's Avatar
The best thing to do is to research how to care for and charge NiCD or NiMH batteries. When you understand charge rates and times, you will make the best charger choice yourself. Sometimes what someone suggest is not for you or just to make a sale ... like the LHS guy. I bought a Duratrax Piranha AC/DC Digital Peak Charger for $50 when my old charger was stolen. I've had it a year now and I can say for $50 it has preformed way above what I expected. I mainly charge my regular sized batts (3300mAh), and when I got a mini-T this summer I used it to charge that battery as well. Any charger with a fixed current I would stay away from unless the price is a serious issue. You will see that a peak charger wont have that dial up timer on it. That is why they call them peak chargers. They stop charging when the battery "peaks" meaning that once a set delta, or change, in voltage occurs the charger stops charging. Sometimes you can get false peaks, thats when it is nice to have a charger that you can program the specs. The Duratrax Piranha AC/DC Digital Peak Charger allows you to change the specs. Charging batteries with a fixed current and timer is not bad, but requires a little more attention and some charging knowledge. I like the Duratrax because once it is programmed for the type of battery you have its just a matter of cooling batteries, slapping them on the charger, hitting a button and killing some time. Like I said it would be to your advantage to learn about charging and maintaining batteries.
Justa quick little lesson here, most chargers are designed to charge sub C size cells. These are the size of the cells that make up your common 7.2v - 9.6v RC car battery packs. Depending on the capacity, or amount of charge the battery can hold, will tell you about what current rate to charge the battery pack. Say you have a 7.2v 3300mAh pack, you can safely charge the pack @ 3.3 amps or even higher, when charging at a higher rate you have to monitor the temp of the pack so it does not damage the pack. Say you go with the safe 3.3 amps. 3.3 amps is the same as 3300 mA (milliamps). mAh stands for "milliamp hour", charging a 3300 mAh pack at 3.3 amps will take about 1 hour to fully charge, if you can safely increase the amp rate, your charge time will go down. This is all good for sub C size cells, but when using smaller packs for your 1/16th and 1/18th scale cars, most packs are made from smaller size batteries usually 2/3 A size. These smaller size cells have to be charged at lower rates or they will be damaged. Once you learn about charging Sub C cells you can apply that to 2/3 A or other size cells but you have to remain within the specs for the smaller sized cell. If you can find the specs of the individual cell, you will know what rate to charge with.
If I were making the choice you are, I would get the Duratrax Piranha AC/DC Digital Peak Charger, it is good for a beginner or everyday basher. If you get serious about racing and battery packs, you can get a top of the line charger in the $100+ range. I didn't want to say that but I did anyway !!!
Honestly once I learned about charging, discharging, and maintaining batteries, knowing what I needed from a charger and what to look for made the choice easier.
Back when I started this hobby in the 80's, we only had NiCD batteries, I ruined several packs before knowing my mistakes. Thanks to newer batteries like NiMH and the Lithium based batteries most of the mistakes I made are things of the past .... and forget about discharging new batts every run !!!
Old 01-04-2007, 07:50 PM
cjg
cjg's Avatar
ORIGINAL: Dokioto
That one specifically says it won't work on mini 2/3a cells:
"Note: Do Not Charge -OR- Discharge Battery Cells smaller than Sub-C Size
("Sub-C" is one size smaller than a "C" size)."
Old 01-04-2007, 07:53 PM
Dokioto
Dokioto's Avatar
ORIGINAL: cjg
ORIGINAL: Dokioto
Thats strange... It's working well...[&:]
Old 01-04-2007, 07:54 PM
Mattdg67
Mattdg67's Avatar
Dude save your money and get the Brain 959. Its worth it.
Old 01-04-2007, 08:16 PM
subyman
subyman's Avatar
I agree with the Super Brain. I have the 819 (do not use with 2/3 AA batteries!) that I use on my 3300mah packs. It works very well and gives a quick charge. I am going to pick up a 959 to replace it since I have a mini now. I highly recommend these chargers.
Old 01-04-2007, 10:19 PM
running_gag
look for peak and look for adjustable charge rates. the super brain 959 will charge your mini bats and your e-maxx batts.
this is another good one. http://www2.towerhobbies.com/cgi-bin...&I=LXCLD5&P=ML
but read everthing before you decide. some people will give you bad advice because they want to appear intelligent. others will just because they have been lucky. learn, ask questions, learn some more.
Old 01-04-2007, 10:38 PM
Doahh
Doahh's Avatar
ORIGINAL: running_gag
Get this charder this charger and this charger alone... it will save you time frustration and money...
Old 01-05-2007, 12:29 AM
SubaruSti
SubaruSti's Avatar
I have a 959, and I use it for 1/10 packs and my mini. It is $25 cheaper than the charger the original post asked about.
http://www2.towerhobbies.com/cgi-bin...&I=LXAVN1&P=ML
Old 01-31-2007, 09:53 PM
hou
i really really really need to no the best charger for under 60 bucks
please help
thanks
Old 01-31-2007, 10:00 PM
-Inverted-
-Inverted-'s Avatar
ORIGINAL: hou
please help
thanks
Here ya go!
Old 01-31-2007, 11:33 PM
hou
and the best battery for a rc18t
