Inferno st steers like s*%# HELP
Got my daughter an inferno ST she picked out. Shaved some stop out of radios wheel got some more steering. My 1/8th MBX5 can turn around about the same area with the pivot cups cut out some.You can't use a standard servo & add arm length because they used some lame 4 wire crap on the ESC- REC COMBO-.We saw a couple associated RC18Bs run they were super quick and nimble and had seperate rec. ESC and what looked like you use an upgradable servo.They just had a little whistle to them & a stock rechargeable batt. Hers sounds like alot of gear mesh.I'm sure hopped up the inferno would mash on them but i was dissipointed when i compared the two on the carpet track. The kyosho's batt was 60 upgade @ LHS too"WHAT THE @#$%" got a integy for 18 coming from ebay. SO FAR NOT IMPRESSED DAD .................Anybody got a couple of suggestions we have a reciever for her JR PRO radio but i'm hoping to not sink alot $ right now just set up a MBX5 PROSPECT FOR HER TOO
MI
RE: Inferno st steers like s*%# HELP
The Inferno series has alot of gear noise, yes. The main problem you are experiencing is in the open center diff though. Try a ball diff in the center, and play around with diff amount's of thick grease in the front and rear diff for the handling you want.
My Feedback: (138)
[8D]hi guy,s . i tried that jrgunn5150 it worked lol made mine quiet and inproved the handling . i also shimed the stering with small washers that helped the stering .
I know if I buy new electronics it would be sweet but you my as well get the new 8000k mamba and with a used MBX5 prospect all set up for her and my RC addiction I'm not ready to drop that kind of funds right now.I set it to about 2 tow out and with the 9.6 bat the servo a little quicker.These have seald diffs for silicone oil what you guys using
