Charging a 7.2v 1100 NImh Battery?
I have a 7.2 1100 Nimh battery that i would like to charge. I have the Duretrax intellapeak pulse charger. I was wondering what amp setting i should charge my batteries on peak charge? and any other tips you would recomend
RE: Charging a 7.2v 1100 NImh Battery?
As a general rule the slower the better. If you have the time then charge it at around .3 amps or so. If your in a rush then charge it at 1.1 amps. Try to avoid going above this.
OH
Well, a rate of 1.1 amps isn't the best charge rate. It is the highest rate at which you should ever charge an 1100mAh (A.K.A. 1.1Ah) NiMH battery. As GRANT ED said, slower is better if you have the time.
