New mini baja shocks
TN
Hello.
I have just installed a set of GPM aluminum shocks on my mini Baja. I am using medium springs front and rear and 20wt trinity silicone shock oil. IT IS AMAZING!!! the difference in handling is unreal. the car is a lot more stable in corners and can jump 3x higher without bottoming out. Plus, I no longer have to worry about the leaky stock shocks. I also think it looks SWEET!!! Check out my gallery for more pics. lemmie know what you think.
Jack
Jack
RE: New mini baja shocks
Did you have to sand the bottom pieces to get them to fit right? I did.
The bottom pieces are also weak so you should get some extras incase they break. Mine did.
Other than that they are great shocks, more importantly cheap. Anything is better than stock.
TN
ORIGINAL: Gex_61
No I didn't have to sand the arms. the shocks fit a little tight, but went right on. I love them. they work great. And you are right, anything is better than stock. I have not broken an arm yet, I have snapped a few turnbuckle ends, but thats about it. I slammed it head on at full speed into the tire on my real car one day and all it did was pop the left front lower turnbuckle cup off the ball, i just popped it back on and it was fine.
