Mini t upgrades
NC
Mini t upgrades
I've asked before but would still like opinions from others. Please don't reply back saying search because opinions do change from time to time. I have a stock mini t with the team losi 7.2v 100 nimh battery. I'll get the losi oil filled shocks. Should I get the losi bearings or another brand? Which motor would some suggests to me? Should I get brushed or brushless motor? Which esc? What else should I look into? Everything (motor, electronics, battery) gets pretty hot when ran the way it is. Any help would be appreciated. Thanks
PA
RE: Mini t upgrades
It all depends if you want to go brushless or not. If your willing to spend the money, go brushless; it will save you money in the long run.
With brushless, the stock slipper willl not hold up to it. Get a dual disk slipper.
Losi bearings are fine and cheap.
Be preapared to change your tires if you go brushless
A ball diff is the way to go; your stock gear diff will not hold up to that kinda power.
PA
RE: Mini t upgrades
B-p-p.com sells the most powerful bl motor, the mamba 8000.
As for brushed, the trinity micro-monster wild is powerful and also the orion baja.
Get an ELITE 1500 pack off cheapbatterypacks.com, they're the way to got.
Mamba: http://b-p-p.com/proddetail.php?prod...mamba8000combo
ELITE 1500: http://cheapbatterypacks.com/main.as...rer=3&model=20
BAJA: http://www2.towerhobbies.com/cgi-bin...?&I=LXFWS4&P=7
Micro monster wild: http://www2.towerhobbies.com/cgi-bin...?&I=LXGTE2&P=7
PA
RE: Mini t upgrades
Actually, i did some research and orion has a 1600 pack: http://www.horizonhobby.com/Products...rodID=ORI13024
I might actually pick that up......
RE: Mini t upgrades
No, you need to buy a different servo and a Radio system. I would not recommend BL if you are just starting out just get a better brushed motor and once your skills are built then go BL.
CA
RE: Mini t upgrades
I'm running my stock Mini T with 7.4v CSRC 1250mAh LiPo and Team Losi Insane 370 motor. The only other upgrade is GPM oil shocks. All the upgrades only cost me $60 and was pretty simple to install.
check out this vid jumping my Mini T....
http://www.youtube.com/watch?v=zv8fNdiF8U4
I also have a BL Mini Baja with Mamba 25 and 8000kv BL Motor, also running the CSRC 7.4v 1250mAh LiPo. It's got so much speed, it's ALMOST too hard to control!
But a heck of a lot of fun!
Dynamite just came out with the C4 a 9200kv BL Motor! Quark has a pretty 22A BL ESC worth looking into. However, the Mamba 25 with castle link USB cable makes programming a snap!
