Best LST2 Brushed motor opinions
Ok, I started with the stock frenzys, went to the insanes, which because of the GARBAGE stock esc in the lst2 caused me to replace all the electonics. Then decided to go Mamba 6800. Which with all the cogging and inconsisencties made me decide to go back to Brushed. But I want some more top end. Ive tried several gear options usung the insane and its close, but I want more. Also I am going to get a 2 cell lipo so keep that in mind with your suggestions. Thanks. PS, what spur and pinion are you usung in the brushed setups. Thanks
ON, CANADA
RE: Best LST2 Brushed motor opinions
If you still have the Mamba esc you could switch to a bigger motor like the Wraith 7k, it has more torque so it wont cog as much.
Ive got the whole set up on ebay right now. I just dont have the patience to tweek it I guess. I get it working one way ok, but causes an issue somewhere else and vice versa. So I went back to my 540 size mc230 esc. And Ill just put a hotter brushed motor and the 2 cell lipo and go from there.
OH
Don't give up dude. I know I've wanted to put my ProPulse on ebay so many times, because stuff just kept messing up. I bought a Vendetta after that, worked on that for a while. Now I'm starting to rebuild my Propulse, and it works again! You just give things some time, and they'll just decide to randomly start working again.
