Micro-T plus Mini-Z motor?
PA
Wazzup,
Will any mini-z motors fit in the micro-T? I was looking at one and it seems pretty powerful at i think it was 45000 rpms. [link=http://www.atomicmods.com/Products/Atomic-Ball-Bearing-Stock-Motor__11087.aspx]Here[/link] it is.
And BTW, is the micro-t stock motor a 130 size?
Thank you!
Thank you!
RI
RE: Micro-T plus Mini-Z motor?
Mini-Z, Xmod, and other motors that are that size are too big to fit in a Micro-T, the only way to get it to fit is if you make a custom motor mount.
RI
ORIGINAL: maxxdout
ok, i mya try that. I will probably get a sheet of carbon fiber and use that, maybe......
PA
LOL, i will. I need to find a site that sells those sheetz. will the stock pinions work or will i need bigger ones???
Thanks!
Thanks!
PA
[link=http://robotmarketplace.com/marketplace_carbonfiber.html]This[/link]is the stuff i'll proabbly use, i just need to know the thickness.....
ORIGINAL: Mattdg67
No.
ORIGINAL: nitro _ burner
isnt cutting CF dangerous???
Yes,cutting CF is dangerous but its eaisly avoided;
Just dont breathe the dust and wear eye protection.
