Charging Micro-T battery?
AL
I really don't care for using the supplied AA powered peak charger that comes with the Micro-T that I just ordered, can I just charge the battery with my digital charger I use for my larger scale RCs?
What rate would you charge the battery at? its a 1/3AAA pack rated at 150mah correct? I suppose you don't wanna charge that too fast. What other battery options are there on the market, that aren't too expensive and don't require cutting or modification?
