micro b lipo question
MN
Hey I just got a Micro Baja and I figured out that I dont like the stock battery. So I was going to get a lipo for it. My first question is I already have a lipo charger but the losest mA is charges at is 250mA. The losi lipo is a 180mA and as far as i know thats where it needs to be charged. So does anyone think the difference between my 250mA charger and the 180mA lipo would be a big deal? The second question is there any other lipos around for the micro's and where.
VA
RE: micro b lipo question
I made 2 packs for mine I did the 7.4 thing first but after frying a new motor I re-soldered the packs 2c in series @300mah and used the largest pinion gear in the kit now you get wheelies for 40min+ and nothing gets hot the cells came from a little foam r/c plane 10.00 apiece I don,t remember the part number
There are 250's around but youll need do have to hack into your chassis to fit 'em in.
otherwise DO NOT charge Li-Po's at the wrong setting, you will regret it. BOOM[:@]
