Micro-baja & Mini lst2?
Hey guys I'm getting ready to buy the micro-baja, and since it comes with lipo, i have a few question i was hoping you could help with.
1. does the stock esc have a low voltage cut off? or do you have to watch it?
2. how long does it normally take to charge the lipo pack?
3. i have seen a lot of people have an issue with the rang on the micro-t, has anyone had the same with the micro-baja?
4. is there any real parts i should get right off the bat?
5. i was also wondering, about the mini lst2? what are the most common parts that go wrong? so i can buy them right away before i have to wait?
6. and is the mlst2 good in small park grass, i have a park with several soccer fields, that has really short grass, Not like the stuff u would have on your front lawn.
7. what would be a good upgrade battery pack for the mlst2? something that will give good runtimes?
8. and can the stock mlst2 wheelie?
Thanks guys.
Thanks guys.
CA
RE: Micro-baja & Mini lst2?
1. no
2. about an hour
3. to make the range better make your own antenna
4. bearings, new antenna
don't know much about the mlst2 since i don't own one.
2. about an hour
CA
heres how to make the antenna mod:
http://www.microtforum.com/forum/viewtopic.php?t=30
im guessing the lipo runtime is maybe 30-45 minutes depending on gearing and how you drive.
Hey, The micro Baja DOES NOT have lipo. It's just an NiMh pack and battery operated charger just like the micro T. I have two of them, and they both are the same as the micro T except that the turnbuckles are clear and a little bit thicker.
ORIGINAL: JC_Dirtdog
if it does not have lipo, y is losi selling them with lipo? and on ebay, they have lipo?
ORIGINAL: pythonfan
Losi isn't selling them with lipo. Here's the link to the micro Baja on losi's website:
http://www.teamlosi.com/Products/Def...rodID=LOSB0232
in the description, it says it includes a powerful NiMh battery pack. Losi does make a Lipo upgrade kit for it that comes with the battery and the lipo charger, so the ones on ebay may just include the upgrade. I am not trying to flame you or anything, I just wanted to let you know this.
Ok for the MLST2 Q's: the only thing ive had go wrong with my MLST2 is both steering servos went at the same time[&:] but they replaced both
Its ok in grass but is best on dirt, grass will cut back runtime and speed. Unless you have a BL lying around
The best battery packs are lipos otherwise the 6 or 7 cell pack are the best Ni-Mh http://www.thetoyz.com/cart/thetoyz_...20POST,%20MISC http://www.thetoyz.com/cart/thetoyz_...20POST,%20MISC
And no it cant wheelie because it has 3 diffs, including 1 in the centere. you can always just lock the centere diff though.
CA
the MLST2 is a great backyard basher!
definately want to run with lipos. I was runing with stock electronics and a 7.4v 1250mAh lipo for a few weeks I only had a couple repairs less then $15.
I just installed BL motor and mamba 25, now I'm running 11.1v lipos.
ORIGINAL: nitro _ burner
The only really problems you should encounter with the Mini LST2 are the stock servos (replace with JR 241) and the stock connectors (replace with Deans). It is a great basher (like everyone has said) and with a few mods/upgrades could be a racer.
ORIGINAL: Dokioto
Six or seven cells are the best? What about eight or more (if you can fit any more lol)? The only reason lipos (lets say we are talking about a 3 cell) are "better" is because they have a lot More voltage, then a 6 or 7 cell Ni-Mh pack.
and i meant without going lipo, nimh are the best. Read through the post again
Uhh qusetion. Do you even own a MLST??? if so you would know there is limited battery space, a 6 cell will just fit and a 7 cell is a real squeeze (ulness you mod the chassis somhow)
ORIGINAL: Dokioto
