Just got a Mini-Rodeo buggy. RC18B clone?
NJ
RE: Just got a Mini-Rodeo buggy. RC18B clone?
ORIGINAL: Mdubz
I think stock gearing is something like 14/60 (Pinion Gear/Spur Gear) or something in an 18b. If you had motor with a bunch of torque, you could gear it something like 18/55 and it would be faster.
14/55 as per the parts listing.
Over here is AUS, i can get one of these knock-off's for aprox $60AUS delivered to my door, whereas the Team AE version is $340 from my LHS, A HUGE DIFFERENCE, i know[&:]
Is it worth getting the cheap version and spend the rest on a BL system ($150 for motor and esc. either 8K or 9200KV motor) a battery (li-po either 7.4V or 11.1V. ranges from $40-60) and some alum to replace the weak spots(im thinking like shock towers, arms, drive shafts mabye??) Can anyone please suggest what i would need to get to male it strong enough for BL speeds??? keeping in mind i have a budget so no un-neccesary things.
Cheers.
Cheers.
NJ
Got my associated heatsink/motor mount and my venom mini fireball 370. just waiting for the batteries to charge. I need a better charger, one that doesn't take 5 hours.
OH
I had been thinking of getting me one of these Rodeo 18B clones to compliment my 18R I recently bought, but instead snatched up a Tamiya TamTech chassis kit from eBay for pretty cheap.
But they look like with a few choice upgrades that they would be good performers.
#31
NJ
I think I may go brushless.
I have a 11t pinion on this Fireball mini 370, so my gearing is 11/55. Is there a better combo I should try? I have a 12t and a 14t pinion gear on hand also.
#33
FL
would it help on the minis to boil the plastic parts? I have a mini t and have only burned out a motor and steering servo, but eventually something will break.
#36
NJ
thats a good idea, specially since they are $9 for the pair. They are plastic? I hope they are strong.
#37
OH
The RPM stuff is very durable. You would more likely to break all the other pieces on the vehicle before any RPM stuff.
#39
For the gearing, base it on how it performs, essentially it should stay within a reasonable temp. then you tune it to how you like it, for eg, more bottom end, more top end (more top ended set-ups will generally lead to over heating)
You have a good range of pinions, i would suggest just buying the setup then starting off with the lowest tooth pinion and going from there.
#41
ORIGINAL: oneglory
I guess process of elimination would be most effective.
#43
NJ
I want to get the MIP swingshafts cvds, but I'm not really sure if they will fit. And to be honest I can't see how they install into the diff.
#44
ORIGINAL: oneglory
MY GOD! i cannot belive you put all that time and money into that thing. you have a rc18b by the time your done. i also watched those auctions when they were under $20 for my son but for $35 and $35 shipping i rather just spend a few more bucks for the rc18t. yoiu should have burried it in the knockoff cemetary. but now your stuck in
dont put any more into it :P get a rc18b
#46
NJ
ORIGINAL: irlsh
ORIGINAL: oneglory
I'm enjoying it and am learning a lot. I don't see a problem. I'd end up upgrading an rc18b anyway.
#47
nothing wrong with enjoying and learning for sure! just a shame you had to be an example of it. but i agree nothing wrong with enjoying and learning . and LEARN TO FIX you have.. let us know how things go in the end. but tell me. i was watching those auctions as well to get one for my son he is only 5 he plays with mine already. how much abuse will it be able to take ya think? i mean how hard were u driving yours?
#48
NJ
ORIGINAL: irlsh
really good actually. I didn't break until I hit my car's tire at full speed..I dunno what happened but the steering stop responding. It broke the shock tower. I would also have to say the stock motor mount is garbage, the screw threads just disintegrated.
#50
NJ
yep. I already ordered a replacement, which is good because I kinda bent the plastic all up while taking the spur gear off.
