this work on micro-t since i blew my esc will this work in place of that ??
FL
FL
RE: this work on micro-t since i blew my esc will this work in place of that ??
whys that ?? i wa told all i need is a reciver and so i just went ahead and got reciver and controller ?
Moderator
The ESC and the Reciever are 2 different things, the micro T happens to have an integrated unit, so if you blow one you blow both. You need to buy a new ESC, Reciever, and steering servo.
FL
the receiver included with that radio is way to large for the micro-t. also the 2-in-1 unit for the mini-t is also far too large. you need a small esc, a micro spektrum or airplane receiver, and a servo such as the hs-50.
Moderator
ok, clearly this isnt working.
Both the mini T and the Micro T have reciever/ESC combos in one unit. The Mini-T one is too large for the micro-T. Therefore, you either have to buy a replacement micro-T electronics package, or a separate ESC, reciever, and micro servo.
OR
try this link instead, about the same price as the radio-receiver you were looking at....this is what you need
[link=http://cgi.ebay.com/LOSI-LOSB0803-RECEIVER-ESC-RX-UNIT-Micro-BAJA-NIB_W0QQitemZ280159499303QQihZ018QQcategoryZ44028Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem]Micro-T ESC/REC Unit[/link]
FL
nah im possibly getting one off of one18th.com for like $15 and i get the tx and battery and charger so its a deal thanks for your helps though
