OFFICIAL RC18MT/B/T THREAD
#676
TX
RE: OFFICIAL RC18MT/B/T THREAD
great and very helpful thread.
here mine is
bone stock cept a littl wheel bling...
only complaint is the well known steering slop problem but have a drag link coming
i am used to my MGT and this thing is only as big as one tire [X(]
here mine is
#677
CA
I dunno if this question has already been answered, but i just finished my FT kit and i think i left my diff gears a little too loose, does anybody have any idea about the force it should take to turn them, as i think the manual is unclear.
#678
CA
ORIGINAL: *BUBBA*
#680
Banned
ORIGINAL: calvino
the diffs should be at around 1/2 a turn out from dead tight[8D]
Because that's way looser than the factory-recommended 1/8 to 1/4 turn.
#682
CA
ORIGINAL: Dan|zu
were those the regular stock rubber tires that went bald or are those Foam tires??
#684
PA
hey guys i got a few ?'s i might be getting the factory team for $90 sealed in the box, good deal? WHat is a cheap but OK motor? and a cheapo esc? I have a Futuba magnum 2PL radio ill use, umm well can it handle grass? and how is it durability wise? Thanks guys!
#686
PA
this is what he is selling
new FT rc18t kit still sealed $90
1 new xray 18t kit still sealed $90
1 new xray nt18t nitro kit(this is the kit with no elec.) still sealed $160
so it is a good deal?
#687
CA
hello all this is my first post on this thread. i am out in iraq and posted a poll earlier for your guys help on a mini, after the results were in i eneded up getting a rc18MT, i hope this thing is a great as you guys say in these threads. so this is my order (below) it's going to take a while to get here since it's going to go through military mail and i'm in the middle of nowhere.
Products
1 x Racer's Edge Super Sport 6 Cell NiCD 1500Mah Battery (RCESS1500) = $9.99
2 x ProTek R/C NiMH AA Loose Battery Cells (4) (1.2V/2500mAh) (PTK-NM-AA2500) = $19.98
1 x Team Associated RC18MT Mini 4wd RTR Electric Monster Truck (ASC20110) = $154.99
1 x Pro-Line Premium Blend CA Tire Glue (Medium, 15-20 sec) (PRO600502) = $8.25
2 x Team Losi Silicone Shock Oil (40wt) (2oz) (LOSA5226) = $7.58
1 x Team Losi Tread Lock Medium CA Tire Glue (Blue) (LOSA7880) = $7.75
1 x ProTek R/C NiMH AA/AAA 4-cell AC Quick Charger w/LCD Display (PTK-NM-AACHARGE) = $14.99
i was trying to think of things i would need out here with not going over budget, shipping was $60 alone so.
what else shuold i get to make sure this thing runs a while out here (under budget)?
is the battery i got going to work with this car?, my wife is sending my charger out here for it.
if i was to start hop ups what should be priority to keep it running cause after this my son (2 now) while be playing with it, he is not to bad when i let him drive my Turmoil so i think he can handel it.
thanks guys i hope this thing gets here soon!
Products
#688
Hopefully this isn't a double post but I thought I would add in a word of my own on the differentials. I use the mid-level mamba system and I have shredded the outdrives as I assume many of us have. I am considering upgrading to the MIP Differential setup ([link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKBC2&P=ML]Tower Hobbies link[/link]). Has anybody run this? Any problems with this particular item or any different recommendations?
#689
CA
IMO the stuff you need for the 18MT is:
Another battery is nice, the stock 1100 can last a LONG time on a charge $20 (ish)
Different battery charger (team losi mini peak is nice) $20
DP GEAR COVER IS A MUST (considering iraq can be DUSY from what i see on TV)
DP Draglink is nice to have for the car (take out some of the PAIN IN THE REAR steering slop)
RPM wide bumper's rly nice, protects the front end of the car
as for the CA i can't think of any problems that you could have with tires loosing glue...
shock oil is a must, 45WT works great (stocks like 30, IMO kindof soft)
batteries for transmitter
and diff shims (1 pkg)
thats all i can think of, if you got any more q's feel free to PM me with em[8D]
#690
CA
thanks calvino for the help. i am going to get the gear cover but i need to wait for something to break it takes a while to get mail out here so i need to order in bulk.
#691
CA
ORIGINAL: 99wolfsedition
#692
CA
is the 1500 6 cell battery i got in my shipment going to work with the rc18mt
what parts fit the rc18mt that are for the rc18t i'm not finding very many hop ups for the rc18mt
thanks guys
thanks guys
#693
CA
is the 1400 battery i got in my shipment going to work with the rc18mt
thanks guys
thanks guys
#695
http://www3.towerhobbies.com/cgi-bin...?&I=LXMGX1&P=Z are these good cells for my 18T, we now only have one "working" battery pack and wanted a good one to use with the car, just currious[8D]
#696
GA
I have an rc18mt and for some reason when push the throttle all the way in the truck just jumps a little but doesn't move anywhere. i have to slowly speed up to reach top speed. does anyone know the problem and how i can fix it.thanks.
#697
Banned
ORIGINAL: D-crum
could be the esc
could be that you've moved the throttle trim on your radio
could be you need to reset the esc
could be the receiver
could be a lot of things
#698
CA
sounds like a voltage drop maybe?? the sudden max throttle draws too hard on the batt? or maybe the ESC is shutting down because it's overloaded.. hrm.. just some guessing. I think trying to reset the ESC (as said above) would be a good start..
#699
MI
does anyone know what it would take to mount robotronics scalpel rims on it? im guesing a hex adapter maybe for the trinity next would work. got any ideas.
#700
CA
sounds to me like the battery, i will have that happen to me when i try and get the truck to move from a dead stop (when the battery is getting low), it will move slightly, and then "die", if i more slowly ramp the power though, its fine[8D], that seems to be your problem
