mini-t tire probelm
VA, AMERICAN SAMOA (USA)
mini-t tire probelm
i have a mini-t runing a 9200 brushless and i cant keep my tires glued run about 5 mins and blows the foam out any suggestions may be bead locks
RE: mini-t tire probelm
Make sure that you clean the tire and rim before you glue. Scuff up the bead of the tires so the CA has something to grab. Belt your tires to help with the ballooning.
