OFFICAL RC18R THREAD
#827
CA
RE: OFFICAL RC18R THREAD
ORIGINAL: mhall13
I kind of looked at everything inside as it came apart in my hands. Is there some slop in the differential? Everything seemed pretty tight, but I am just guessing since I don't have anything to compare it to. I have to admit, it was rather rewarding to put it all back together and find out that it still ran. And, no extra pieces when I was done! Even better. The engineering that goes behind these things is just incredible to me. I think next will be batteries and motor!!
#832
My Feedback: (81)
VA
I know and that is one of the reasons I stayed off the site. I also think there were a lot of kids on that site that didn't help the professionalism of the content.
#833
NY
I just got 1 of these so I thought I'd revive the thread. Got it used but it came with a ton of hopups and even more hopups in a box from when it was an 18t. It needs a motor and I'm planning on going with brushed for now because all I have are nimh packs. It came with this: http://www.teamassociated.com/cars_a...s_accessories/ (aluminum mount/heatsink) and I have an extra duratrax vr3 motor and esc but the can is a little bigger than the heatsink will allow. I also have a bunch of 2mm pinions for it so I'd like to stick to that shaft size. Any motor recommendations? I'll be running on a tight carpet track so not looking for speed. Would a BL motor and nimh packs be okay?
#834
My Feedback: (81)
VA
Well, I guess it's a little late now, but I think you should have went with this.
http://www.shop.gotnitroonline.com/p...7&categoryId=1
They are very fast and don't really need any upgrades. It's not too late to sell yours and get one. I had two and they are screaming fast.
Check out the size comparison.
#835
NY
I saw that, but since I will be racing on carpet, I need to be in the 1/18th scale. I plan to race my vendetta tc in the mod class and the 18r in the spec class. That is a pretty smoking deal though.
#836
I just picked up a 18r.
First question, my steering seems a litle weird. When I turn, the wheels turn but then when I let go of the wheel, the wheels dont go back to center. I have to turn the wheel again to make them straight. What causes this and how can I fix it?
Next, what are some first upgrades to do to the 18r? I have seen people say to get a gear cover. Who makes it and where can I get one?
Also, I plan on upgrading to a BL system sometime down the road. What is a good setup and kv for just driving around in the street, no racing or anything.
#837
My Feedback: (81)
VA
Hi,
You can go to www.thetoyz.com, they have lots of upgrades there.
This is the one that will solve your problem. Been there done that
http://www.thetoyz.com/cart/thetoyz_...cat_name=RC18R
No offense but it would do you a lot of good to read this whole thread. Lots of good info!
#838
MN
The issue with the crappy err ummmm.... Non-precise steering....is the servo saver...
Granted, when you drive this thing, it seems pretty good....but take a look at the rc18t2 (belt version)
It has a Whole new (real type 1/10 scale) servo saver...
I have the intigey entire steering setup, but am going to send it back....
Anyone know if you can place the NEW system from the new 18t2 ??
My guess is it does, as the sytem is instock limited qt's...means hot item...
Other issues....:
Hit something with front a-arms.....one of 3-things happen.....
1. pull the hing pin through the lower arm
2. pull hing pin throug front bumper
3. pull hing pin through/out of the actuall chassis...
All of these happend to me....
Looks like Associated solved the (having to buy a whole chassis plate) by haveing a separate bulkhead from chasis....on the T2 version....
The chassis only is 3$ so not bad...but still, a PITA to do..
I would think the stearing deal would be High on the list to do on this truck...
I am ordering it as I speak....
Other issues....:
#840
My Feedback: (10)
QC, CANADA
ORIGINAL: kochj
Other issues....:
Other issues....:
Have you looked at any pictures of the belt driven RC18's?
It definitely looks like you'll be missing critical anchor points for the bellcrank on both the chassis and the top plate, problem is on both version the chassis and the top plate are also used to mount the motor, spur and differentials. And the new setup uses a transverse mount while the old uses longitudinal. It looks like if you're gonna do the swap, you're gonna have to do the whole thing.
#841
My Feedback: (10)
QC, CANADA
ORIGINAL: Wheelnut
I think I pretty much covered it in my post. It's the drive link.
Oh yeah the DP drag link works great at taking the slop out but in the right kind of dust the stock servo saver jams stuck on one side or centers erratically and it really sucks when that happens. And once it wears, the two parts of the servo saver no longer slide smoothly against each other and cleaning it won't help.
#842
MN
I looked some at the photo's of the 18t2....I must have missed the Top support pieces.....
I wasn't worried about the bottom, As I can easily drill some holes in the chassis...
I could fabricate a top braket..... for the assembly, or work in the kITS plastic piece...\
I will have to look at some more photo's......
I guess the stearing isn't all bad, as it seems I have fairly decent stearing when rolling, it just looks bad when stoped and you
turn the wheels....And the servo saver kicks in....
I guess it does it's job of keeping the servo gears safe...
#843
Those of us that have had any of the RC18's have had to deal with it since the cars were released.
Lots of ways of getting around it, from any of the various "fixes" people have come up with for the stock servosaver to simply upgrading it to a real one. I'd bet there are at least a hundred posts relating to fixing it. Try "search."
The alloy link kit is just bling, it fixes nothing.
The new 18t2 set-up won't fit, doesn't work the same, and the chassis plates are different.
But there's nothing saying you can't find another way of fixing using 18t2 parts, and a little ingenuity. That's what makes this a hobby.
Rule of RCing #1 = If you run into anything that's hard enough, and do it going fast enough, you're going to break something.
Rule of RCing #2 = If you don't want to break things, don't hit things.
Rule of RCing #3 = Slow down.
#844
My Feedback: (10)
QC, CANADA
crunchNmunch, I politely disagree with your 2nd and 3rd rule of RC and propose that it be replaced by "2: if you don't want to break it, shelf it" and 3: "if it feels like everything is under control you're going to slow"
#846
My Feedback: (10)
QC, CANADA
ORIGINAL: Wheelnut
My favorite line is ''ride the edge between fast and disaster''.
I like it!
Of course with a signature like yours such a statement is to be expected
#847
My Feedback: (81)
VA
ORIGINAL: aflipz
I like it!
ORIGINAL: Wheelnut
I like it!
I change my signature around once in a while, it's fun
#848
ORIGINAL: aflipz
#849
My Feedback: (12)
OR
I recently got a used RC18R roller. I also have a couple of Mini-Revos. I am going to use the lipos I have for all of them. I was wondering if the Traxxas VXL 3m motor will fit in the RC18R? I know it's slightly larger than the 1/18 motors the RC18R uses but has anyone installed a VXL system in theirs? If so, were any modifications had to be done and how did it perform? If it won't work I plan to get one of the 1/18 brushless systems on market. Thanks!
#850
ORIGINAL: gforce2448
