Cox 049 mufflers
My Feedback: (10)
BC, CANADA
RE: Cox 049 mufflers
Adrian,
We had them quoted a couple of times (OEM Cox version)and pricing was too high for the low run we were after (1,000).
We are presently having them quoted by another engine manufacturer and, if pricing pans out, will manufacuture them before the end of the year.
Our target is to have a retail price not exceeding $14.95.
Bernie
Bernie
NE
There was someone for awhile that made a silcone rubber muffler that was surprisingly quiet. Not the normal metal idea but who is to say that metal is the best material for this?
Bob
Bob
I think that was someone on the forum here who made a muffler out of blue rubber connector from a .60 size 'piped' engine... and used steel washers top and bottom... and a drilled hole in the rubber for a 'spout' of brass tubing for the outlet. Search for 'cox muffler' or just for 'muffler'.
I'd like to see the kind like the TD R/C came with (same basic style as the one used on the Queen Bee). Easier to have provision for muffler pressure. Speaking of R/C, I plan to soon place an order for one or two of those nifty R/C reedies y'all got. Still not the ideal R/C carb solution, but cost effective, no doubt.
Bernie, MECOA has these Tatone mufflers for the Cox engines. They have less power loss than the OEM ones. Mabe you can cut a deal with them and stock these for the time being until the OEM ones get manufactured.
http://mecoa.com/cbtatone/10.htm
MN
Yuu:
My experimental throttle, would work as a muffler/exhaust diverter as well.
http://www.rcuniverse.com/forum/m_28...tm.htm#2874106
Dave
Dave
My Feedback: (10)
BC, CANADA
That's pretty neat, Dave, congratulations.
In general, the throttle rings work pretty good and they sell well for us.
However, the greatest drawback with them is that they preclude the simultaneous operation of a muffler. Because of this, we developped this product:
http://coxengines.ca/product.php?pro...&cat=13&page=1
Not quite the holy grail but a decent compromise.
I do like your setup and it seems fairly easy for a modeller to make himeself.
Cheers
Bernie
Cheers
Bernie
OH
ORIGINAL: fritzke
Yuu:
Dave
Yuu:
Dave
I have made several mufflers like this. They work great and as for a throttle this throttle also works great if you do a good job as you build it.
ORIGINAL: xenalook
Adrian,
We had them quoted a couple of times (OEM Cox version) and pricing was too high for the low run we were after (1,000).
Bernie
Adrian,
Bernie
Any update on the muffler production?
Many Thanks,
=Adrian=
ORIGINAL: icerinkdad
Bob
Bob
You are correct. I have one around somewhere. You stretch the thing over the head and down onto the exhaust. Darned if I can remember who made it. Mine is gray silicone, relatively thin walled.
George
My Feedback: (10)
BC, CANADA
Adrian,
There was lot of back and forth with correpondance, drawings and samples but we finally obtained a reasonable quote the other day. We will be placing the order shortly and they should be available for sale by March or so.
Bernie
Bernie
Hhhmmmmm... A thin silicone rubber 'sleeve' for a muffler, that you pull down over the head and cover the exhaust. Now, if we used a 'birth control' device, and left it full size, and wired the thing shut on the bottom of the cylinder, and let it hang back under the plane, or inside, it would collect all the exhaust 'slop' and keep the plane clean too. Now, what could we call it?
ORIGINAL: Yuu
George
ORIGINAL: xenalook
Adrian,
Bernie
Adrian,
Bernie
Best Regards,
=Adrian=
My Feedback: (10)
BC, CANADA
Adrian,
Our manufacturer is ready to go but we have not given the go-ahead yet due to financial constraints. We have so many projects on the go and they all cost big $$'s.
We recently made 020 glow heads, killer Bee cranks, 049 TD venturis, 020 RD venturis, 5-Fin glow heads, 049 TD cylinders, etc, etc.
Still a project, however
Bernie
Bernie
