Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Ply Eggshell Fuselage -"Lil Miss Butter Knife" TD .09 4ch Knife Edging Stunt Plane!
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 01-26-2015, 11:16 PM
  #101
combatpigg
combatpigg's Avatar
Oh no...how low can they go...?
Copying someone else's original figurine...?
Old 01-26-2015, 11:33 PM
  #102
combatpigg
combatpigg's Avatar
A piped .25 speed project posted at RCU is as rare as......when Smokin'RV posted his .25 VRDF powered delta project some years ago.
I saw a piped .25 in person on a SIG "prop jet" that was such a great all around performer. The owner would just grab the spinner with his thumb and fore finger, give it a backwards twist and the engine would fire up at a fast idle.
Old 01-26-2015, 11:55 PM
  #103
Pond Skipper
Pond Skipper's Avatar
Lol yes a china knock off in a smaller version in this case it worked out great for me lol..
Yes I spin start them that way too. I had a piped .25 on a pattern plane back in the 90s was a great flying plane and didn't need a 40 size tank to enjoy a flight so saves fuel.
The Macs pipe site has a nice chart for cutting down the header pipe with known rpm readings. 16.7 open and with pipe 17.55 if the header is cut to 3.5" I will cut mine at 4" and start from there on 20% nitro. [TABLE]
[TR]
[TD]Zingali 8 X 6[/TD]
[TD]3.5mp[/TD]
[TD]16,700[/TD]
[TD]17,550[/TD]
[/TR]
[/TABLE]
Old 01-27-2015, 06:12 AM
  #104
MJD
MJD's Avatar
I picked up a piped OS .25 VF... but not the VF-DF.. a while ago and it begs for something like a Kittiwake or a compact sport/pattern something. SmokinRV's delta was one of the three proto Demon .25's I cut a while back. I will circle back to that design shortly.
Old 01-27-2015, 08:28 AM
  #105
Pond Skipper
Heeyah gottah love a tuned pipe on a summer morning breeze..= }
Old 01-27-2015, 07:03 PM
  #106
hllywdb
hllywdb's Avatar
I have a 42" span Kaos (sized the plans down from a 60 and scratch built) with light gear and a Norvel 25 on a pipe. Cross field take offs and then turn it straight up. Vertical 8's the size you would do with a 60.
Old 01-28-2015, 01:25 AM
  #107
Pond Skipper
Yea may have to do up a 25 size Skorch in pattern plane style for a nice mix of speed and thrust.
https://www.youtube.com/watch?v=J2rAFY-IZas
Check this out running on just 36hp
Lindbergh flew the Flivver on a visit to Ford field August 11, 1927, and was the only other pilot to fly the Flivver prototype.
He later described the Flivver as, "one of the worst aircraft he ever flew".
The original designer flew it back and forth to work all the time. Guess its a matter of what you can get use too.
If any one has a vid of this particular 1/3 scale plane flying please post.
Old 01-28-2015, 01:41 AM
  #108
Pond Skipper
https://www.youtube.com/watch?v=GBoFeZwQskk
https://www.youtube.com/watch?v=tn_yt1mkVc0
Old 01-28-2015, 07:09 AM
  #109
MJD
MJD's Avatar
The Hummingbird is what you get when you loop a Gypsy Moth and pull too hard at the bottom. (okay not really..)
BHX had a sad end not too long ago: http://www.aaib.gov.uk/publications/...rd__g_ebhx.cfm
Old 01-28-2015, 12:23 PM
  #110
Pond Skipper
Went to the print shop and had some 36" x 42" plan sets produced
Its a big plus to see a full size prospective on the design the dimensions are good!
Name:	36 x 42 Plans.jpg
Old 01-28-2015, 05:52 PM
  #111
Pond Skipper
The upside of having some plans is boundless and during the construction phase one immediate perk is trying on some other engines for size.
Magnum .15 / Norvel .074 / AP .09 Hornet
ID:	2068700   Click image for larger version
ID:	2068701   Click image for larger version
Name:	AP 09 Hornet.jpg
Old 01-28-2015, 07:52 PM
  #112
combatpigg
combatpigg's Avatar
.................and it doesn't take THAT much more work to build 3 at a time, either.
Old 01-29-2015, 12:50 AM
  #113
Pond Skipper
I have done some production runs and yes building 3 at the same time is much faster. This weekend I will fire up the jigsaw see how it goes.
Old 01-29-2015, 04:21 PM
  #114
Pond Skipper
WELP the verdict is in Slimline Vs. the copycat version
$22.5 vs $15.28
45g / 63mm W x 83 H vs 18g / 45mm W x 61 H
Name:	Pamela American and China Version.jpg
Old 01-29-2015, 04:42 PM
  #115
combatpigg
combatpigg's Avatar
Both versions look like a great value.
I took art in high school and spent some time trying to paint a realistic face. I never was able to get the skin color just right after quite a lot of experimenting. Looking back on the time wasted in that class, it would have been much better spent in a model aviation class.
Old 01-29-2015, 05:14 PM
  #116
Pond Skipper
Yes it works out great for anyone needing a smaller modern female pilot for .061 to .15 size engines the other for 25 to 60 size planes.
Aparent 1/10th scale and 1/5th scale
Old 01-29-2015, 06:54 PM
  #117
hllywdb
hllywdb's Avatar
Is it just me or are the boobs a lot perkier on the 45g ones? I think I would scale up the plane instead.
Old 01-29-2015, 07:20 PM
  #118
Pond Skipper
LOL I was doing just that here is the enlarged version I hung up the plans on the wall to take a pic with a yard stick hanging on the right to reference size then blew it up to 44in span 25 to 40 size version will work great with the American made Pamela Pilot.. and yes they are much more well defined.
Name:	Full Size Plans 37in x 44in .JPG
Old 01-29-2015, 07:25 PM
  #119
Pond Skipper
The print shop will have to make these plans up with two separate sheets as they are limited to 36in width on a large feeder roll of paper.
Old 01-29-2015, 10:49 PM
  #120
Pond Skipper
Here is the .09 wall hang with the yard stick for inch refrences the span came out to 32.5in
Name:	Full Size Plans Wall Hang.jpg
Old 01-29-2015, 11:40 PM
  #121
perttime
perttime's Avatar
Handling smaller pieces of paper is easier anyway.... Splitting your plan to 2 or even 4 pieces would just make things more handy for you.
Old 01-30-2015, 05:40 AM
  #122
Pond Skipper
Here is a comparison with the Slimline version and the other one. The fuselage would need to be around 31in min to shoehorn in the pilot.
Name:	Plans Lil Miss Butter Knife1X.JPG
Old 01-30-2015, 05:47 AM
  #123
Pond Skipper
Hi Perttime, Yes very true so I have printed out 4 full sheet copies and plan use one to cut out the shapes and transfer to poster board to create templates.
Old 01-30-2015, 12:39 PM
  #124
Andrew
Originally Posted by hllywdb
Is it just me or are the boobs a lot perkier on the 45g ones?......
LOL --- I thought the same thing. Looks like one's on silicone and the other is on steroids.
Old 01-30-2015, 07:40 PM
  #125
Pond Skipper
https://www.youtube.com/watch?v=eXt6qUHMRu4 Heavy Metal
