HELP please? (Tri-Star)
TN
I have a freind that gave me a Sig tri-star. He did not know how to build the plane. I finished it and have an OS 25 LA in it. I just need to know where the CG point is. I have looked every where.
Any help is very greatful.
Larry
Larry
RE: HELP please? (Tri-Star)
Hi FREEBIRD! You can't go wrong with 20-25% of the wing chord [counting ailerons] . For example, if the wing chord is 10 ", then it should balance 2 to 2 1/2" from the leading edge. If you set the elevator travel for 1/4" up, and 1/4" down, you should have enough pitch control to fly it.
