Norvel exhaust deflector
MI
RE: Norvel exhaust deflector
Norvel sells silicone tupe just the right size. After melting off a plastic tube extension I bought one and it is still in use. I had to repair a Dave Brown Sixshooter pump and bought the repair kit which included silicone tube just the right size. I replaced the old tubing in the pump with new and used the old for Norvel exhaust extensions. It works better than the stuff ordered from norvel.
Another option is to use a "FLY QUIET" tuned pipe. It quiets the exhaust note, increases power and redirects the residue about a foot further back.
TX
ORIGINAL: MikeSell
Thank You,
MI
I found them on ebay. Do a search for fly quiet.
They are designed to raise torque at a lower rpm than with just a muffler. The flexable material that they are made of absorbs sound and the lower rpm the allow quiets the prop noise. I have not done the testing to substantiate their numbers. Go to their web site and make your own judgement.
http://www.flyquiet.com/products.html#norvelquiet
FL
i use general silicones small exhaust deflectors. i think norvel made some red ones also. and duratrax extensions for their maximum mt truck fit well, too; they are blue. a freind had the norvel "tuned pipe" once. never got it to increase performance, but a neat idea.
a lot cheaper than deflectors is the tube used in construction for a water level. It is transparent and extremely cheap, and wont suffer fron fuel or heat. Besides it´s the ideal size so it wont fall or be too hard to plug in. Only thing is that it turns a little red with red fuels.
Good luck
Good luck
Gentlemen:
On the Tiggerkitty I have a pair of the genuine AMD engines, their exhaust stacks are straight out the back of the muffler instead of having the nubbin out at an angle as on the Norvel supplied engines. This allowed me to run piping through the nacelles with a rear mounted outlet. See pictures.
If you get ambitious with a lathe you could make new rear caps for th Norvel mufflers to do the same thing.
Bill.
Bill.
FL
http://www2.towerhobbies.com/cgi-bin...&I=LXLY17&P=RF is a link to the duratrax deflector. here is a pic of same. about 2.69.
Bill.
Bill.
Darren
Darren:
Thanks for the kind words about the Tiggerkitty. Being a woman, she appreciates all compliments. My oldest (and first) r/c twin. She's the plane in my avatar.
Thanks for the B-25 also, I'm looking forward to its arrival.
Bil.
Bil.
