Vee Leading Edge
VA
Vee Leading Edge
Has anyone ever made a wing leading edge like this? I noticed the E-Flite Brio 10 ARF uses this type of construction, and it seems plenty strong. Laser cut ribs probably makes the job easier, but you still need to shape the joint between the two sheets at the front.
RE: Vee Leading Edge
I've done a couple that way and I'll do more. It's a great way to help ensure that the critical first few % of the leading edge is accurate and light at the same time on a wing with otherwise open construction. It goes really well with multiple turbulator spars so that the covering is better supported. For my part I didn't find that it was that hard to get a nice straight joint. A shaping template is a nice tool as well. It's probably overkill on most 1/2A sized models but one of the wings I used this trick on is an RC hand launched glider. For that case the wing section is more critical since there's no engine to haul it around.
