Hitec HS-55 Connectors
My Feedback: (17)
PA
I am new to the 1/2A stuff. When I received some Hitec HS-55 servos, some of the arms have .070 diameter holes in them. Does anyone know what kind of pushrod connectors fit this size holes? My E/Z connectors all have .062" shafts.
My Feedback: (7)
NC
RE: Hitec HS-55 Connectors
The DuBro park flyer/micro pushrods should fit. However, if memory serves the EZ connectors for those products have the same size stud as the standard size EZ's. So basically, if you plan to use EZ connectors you'll have to drill out the holes or use different arms. I have done both.
Brian
Brian
My Feedback: (17)
PA
One servo arm has the .035 holes that you describe. However, the other arm has .070 holes. These holes are bigger than what the E/Z connectors take (.062). I was wondering what connectors would fit these big holes.
