1/2A sized Giles G-202.
My Feedback: (10)
UT
My, what a nice looking Wattage Giles G-202 we have here...
I say... that doesn't look like part of an electric motor under there!
Is that what I think it is?!?!
Oh dear lord, please make it go away!
Flight report/ crash test results to follow, pending arrival of reciever.
FL
RE: 1/2A sized Giles G-202.
I love Giles and I love little 4 strokes, don't make much more noise than a geared electric. What is that engine? What servos you using? I bet you could find a battery that weighs LOTS less than that. 4cell Nimh 370 mah will run little servos great for multipal flights and weighs 1oz.
Nice job!... I have one but havn't flown it in a while. I have an AP .09 and an APC 7x4 Prop. It flys OK but definitely needs more power and bigger prop. .09 can't handle it. Yours should be a blast with the 4S. The plane is real snappy and lands HOT. The pin-striping come off easily( not intended for fuel residue ) so make sure you glue them down good. I used the aforementioned 370ma battery and mini servos. Even with everything back as far a possible I still had to add 4oz to the tail for balance. The AUW is still less than the recommended electric set up.
Keep us posted on how yours flys!
My Feedback: (10)
UT
It's an OS FS-26, and I have HS65 servos in there. I have a 4 oz. tank, but may try a 2 oz. tank if it turns out to be too heavy with a full load of fuel (or just not fill the tank up all the way). As for the battery... I could use a smaller one, but it's what I have, and it helps balance out the plane. I'll still need tail weight, but nowhere near the 4 oz. like mentioned above.
I'm not taking this whole thing too seriously, so spending money on a small battery pack doesn't interest me a whole lot.
