049 surestart info
049 surestart info
Hi, I need some info on the o49 surestarts. what %nitro do they use? any particular gas tank that works best with them?
any info you have about anything on these will help
THANX!!!!!
THANX!!!!!
RE: 049 surestart info
Hey Jason. You will probably have the best luck in starting your engine with high nitro fuel, like 25% or more. You can buy 1/2A fuel in pints and quarts so you won't have to shell out for an entire gallon (which would go bad before you could burn it all in a surestart, anyway). Good 1/2A fuel usually has about 20% castor oil. SIG sells a 1/2A blend that lots of people use. Sullivan makes 1oz and 2oz tanks that are just right for 1/2A use. Hayes has a 2oz tank that I've used, too.
