AP Wasp .061 with RJL diesel head.
RE: AP Wasp .061 with RJL diesel head.
Perhaps not if this is your first diesel experience. If you don't have the "diesel feel" for hand flipping and the patience to just flip the prop after just a prime (no tank) time and again to burp and short run the engine to get the feel of the right compression setting you can break the rod or the crank pin in a hurry. On the other hand, patience and tossing all your "glow" experience and expectations out the window could produce a nice running diesel for you.
If there is someone with diesel experience where you fly ask for help. If not, PM me and I'll help as best I can.
If you can flip a PAW .06 you can certainly try the AP .061 conversion with some confidence. Use an 8/4 or even a 9/3 wooden prop and put it on with the blades at 10 am and 4 pm when the piston is at the top of the cylinder. Just intake prime and flip, starting with the head at minimum compression. Raise compression in small increments ( 1/16 of a full turn) until you get signs of ignition and then short bursts. When you are getting consistent flip starts with small intake primes then connect the tank and go for slightly longer runs. Don't go for higher RPMs until the engine is running consistently at the lowest possible compression with the big prop. If you're sensible about things and don't overcompress and lean it out too much trying to get glow-like RPM with a small prop, you'll have some success with the conversion. Just remember it is now a diesel and keep the prop bigger than glow use size (perhaps minimum 7/3 or 7/4) for flying. Big prop, low compression, and slightly rich make for great flying!
