Go Back  RCU Forums > RC Airplanes > "1/2 A" & "1/8 A" airplanes
Reload this Page >
Seized up Cox 0.049"
"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
Old 12-20-2006, 02:09 AM
Shobosh
Default Seized up Cox 0.049"
Greetings
I have an old 0.049" engine that used to belong to a plastic PT-19 kit. I last used it about 20 years ago and understandably, it has seized (locked) up. I can remove the cylinder OK, but the crankshaft is locked solid.
Onyone recommend a suitable magic fluid for releasing the crank?
TIA
Shobosh
Old 12-20-2006, 03:00 AM
burtcs
Default RE: Seized up Cox 0.049"
Easy, soak the case is fuel or de-natured alcolhol for a day or two. It wouldn't hurt a thing to soak the whole engine then carefully take every thing apart and clean it. It may or may not need a rebuild kit. No big deal...
HTH - Steve B.
P.S. The caster oil will over time turn to a varish/goo-like suff that can lock things up, the alcohol is the solvent.
Old 12-20-2006, 08:31 AM
Andrew
If soaking doesn't free it, then hit it with your heat gun. Castor will also loosen up as it warms up.
