"1/2 A" & "1/8 A" airplanes These are the small ones...more popular now than ever.
1/2A SCALE PLANS
Old 11-25-2008 | 10:19 PM
Default 1/2A SCALE PLANS
Where is a good on-line supplier of 1/2A scale plans?
Old 11-25-2008 | 10:59 PM
vicman's Avatar
My Feedback: (10)
Default RE: 1/2A SCALE PLANS
UlmerRC.com
Old 11-27-2008 | 12:06 AM
Site doesn't exist. Any others?
Old 11-27-2008 | 12:08 AM
Its actually www.ulmer-rc.com
Build a DNU!
Old 11-27-2008 | 03:29 AM
longdan's Avatar
I second the DNU. Forget about scale 1/2A. Build something that actually flies well.
Old 11-27-2008 | 04:24 AM
Go to AeroDyne ([link]http://www.freeflightmodels.com/[/link]) , Plans and Kits. Miscellaneous Scale has a bunch of Flyline designs which were specifically for 1/2A RC - called Schoolyard Scale back in the 70's - 80's. A lot of the other plans could probably be modified to work.
Old 11-27-2008 | 10:50 AM
vicman's Avatar
My Feedback: (10)
DNU is a great choice [sm=thumbup.gif]
His kits build super quick too if you want to buy one.
Old 11-27-2008 | 11:40 AM
Yuu
DNU is an excellant choice. The problem with scale is that the planes mostly use big, heavy radial engines and had a very short nose to balance the engine weight vs. the tail feathers. That means, for true scale, it is very difficult to have that short nose up front and balance the plane without a geat deal of extra weight in the nose; extra weight to the point where the plane is now too heavy to fly. But if you want a 'hanger queen' for static display, go ahead.
Old 11-27-2008 | 01:30 PM
DNU sounds and looks good, but I don't want a kit. I have many kits under my belt and want to try scratch built from just plans.
I want it converted to electric with possibly a Eflite 400 brushless motor. But this needs a ESC and wire connecting.
I prefer to use the 550 brushed motor I have (the motor from a Vista EP sailplane) because it already has the ESC connected and its ready to use.
Can the 550 motor be used on the DNU? It has a 8x4 folding prop and I don't know how to change it if I had to, so I would like to use it just as it is.
Old 11-29-2008 | 11:37 AM
OK, I guess there is not many online sites that have plans available. I think I would like to try the DNU.
Old 11-29-2008 | 11:48 AM
rainedave's Avatar
If you have a particular plane in mind, I might have plans for it. Exempli gratia:[sm=rolleyes.gif]
David
ID:	1080764   Click image for larger version
Old 11-29-2008 | 12:03 PM
skaliwag's Avatar
Do you know the watt output of your 540 / 8 X 4 combo?
What does it weigh... Might be a little on the heavy side
Old 11-29-2008 | 12:16 PM
http://www.crowriverrc.com/My_Homepage_Files/Page1.html
some other plans
Old 11-29-2008 | 04:05 PM
I do not have that info. The motor is an economy brand with no markings on it to provide operating details. It is the motor that was supplied with the Tower Hobbies Vista EP arf.
Anyone have any details on this?
Old 11-29-2008 | 05:46 PM
combatpigg's Avatar
I consider Guillows a valuable resource. You can convert their kits easily to building methods that work for RC and they throw in molded parts to boot.
Old 11-29-2008 | 07:53 PM
av8rsodt's Avatar
My Feedback: (23)
I built the Rearwin Speedster Rainedav posted above... from RCM 11/77. Great flier on a TD .049 and 3 channels: throttle (Ace throttle sleeve), elevator, and rudder. I scaled up the plans to a 48 wingspan since the original wing area would have made it too fast.
Lots of scale plans out there that would be fun to build. Scale plans are a ton of fun and fly very well, but they do require a lot more time and effort (well worth it). Also, they are a nice change from the boxy standard models commonly seen.
I also have a bunch of plans available if you are be interested.
Brian
