RE: throttle barrel stuck how to undo?
Use a solvent (alcohol, glow fuel, etc) right on the throttle barrel. Then add a little heat from a heat gun if you have one. maybe a hair dryer will help. The arm that rotates the barrel is attached with a screw or press-on fitting. Once the barrel is freed up, the arm will work OK again.
