RE: Sickle f3a
Ok Mike thanks for the info.
I fly Advance so the battery demands are less than what you need in Masters I assume.
If you don't mind I'll use you as a guide on this build to keep me from making the same mistakes you and others did.
What batteries do you recommend other than the ones from Chris? I'll be getting some from him for comps but would like to use some cheaper packs to learn the process with and get "Used" to this electric stuff. If I kill them I'd rather they be cheap.
I've only breathed Nitro for 30 years now.
I see the fuse we're getting does not have the same plates in it as the one you first had. I fly JR servos and intend to stick with them.
I'm sure I'll have 1,000+ questions when I start the build.
Such as which lipo/reg set up to use for the flight pack. I'm still using nicads
Tim
