RCU Forums - View Single Post - Designing a new pattern model
Old 09-16-2010 | 02:46 PM
  #166
iflyrctoo
Default RE: Designing a new pattern model
Very nice plane Alex.
You could get it under easily with a different motor such as a Plettenberg. Did you run a single 4 wire lead back to the elevator servos instead of seperate servo leads? That would be good for 10 to 15 grams. A Jaccio regulator is 15 grams instead of 38 (Not sure it's available where you are). You are close. I'm sure with a little tweaking you will get it under.
Joe Dunnaway
