RCU Forums - View Single Post - What to do first??
Old 09-18-2010 | 01:57 PM
tn102's Avatar
tn102
Default What to do first??
I just got a old nitro rustler, and it doesn't run. It has a pull start motor, and it doesn't pull. The pull starter part was just replaced, and it won't budge. It did for a little bit pull, and start the engine, but now it does not. The person I got it from thinks the motor seized, and needs a new one. I do not know anything about nitros, and need help with this. I don't think it is a stock motor either, because the exhaust pipe (i think) has a little pipe that comes off that and points outwards from the body, and it doesn't fit into the little spot icut in the body where it would go.
Also, as of right now I do not have a transmitter for it, and I just plan to swap the crystal out of one of my electrics to it, since I can only drive one at a time. I need to know though is how many channels do I need for it. I will eventually get a transmitter, but I would like to get it running first.
