ORIGINAL: kent_man
... but it should have been tight enough from the factory.
Are you kidding? I wouldn't trust that any parts from the factory are true and tightened. You have to give all that **** the once over before you go out and drive. Plus, you've already run FIVE packs through it previously, doesn't matter if they are NiCd or Lipos, stuff is going to come loose over time. Its not the trucks fault.
