ORIGINAL: chuckmfnnorris
i'll i am going to do is bash around, i live in ct and its gonna get cold soon, not sure if the temp makes a difference in what fuel and glow plug you use.
If you plan on running in cold weather then you should use hot plugs. they will help get your engine started and keep it running. as far as fuel i wouldnt run anything less than 20% and nothing more than 25% to bash. if you have issues with your engine stalling during cold weather you might want to lean abit. It will help keep engine temps up.
