RCU Forums - View Single Post - Pilot RC 73" Sbach
Old 09-25-2010 | 01:55 AM
  #102
boostoman
Default RE: Pilot RC 73
ORIGINAL: boostoman
Im just finishing off my Sbach 73" with a DLE30 rear carb . i was wandering if you guys could help me with some queries i have:
- what is the optimal CG position for normal flight no 3D stuff?
- what angle of the defelctions are you guys using for normal flight. i need s starting point.
- i have a Xoar 18x8 prop on the plane , would 2,200 rpm idea keep the plane slow during landing?
- would a 3Amp BEC for the ignition be sufficant for 8,000-9,000rpm motor?
i would also apprecate if you guys could post your electronics layout pics, i would like to have a clean wire setup in the cockpit. so i will defnitly like to see some examples.
Thanks in advance for your help.</p>
anyone can help me with my questions.
also is a 1,600 mAh 2S lipo battery sufficant to run my servos for at lease 3 10 min flights?
