RCU Forums - View Single Post - Elect. Ignition
Thread: Elect. Ignition
Old 07-29-2003 | 01:19 PM
DougT's Avatar
DougT
Default Elect. Ignition
bobdd,
Jerry Howell sells a TIM 6 electronic ignition kit for about $41. This includes the circuit components, Hall sensor, and Model Electics coil. You will have to provide some misc. wire, a plug wire/boot, and 6v. battery. I used a shielded 14mm wire/boot from CH Ignitions. The whole package weighs 3.25oz and works fine. Since it is a fixed timing unit, I set mine at 25 BTDC and seems to run well.
You could do a search on here and come up with the address.
Good luck.
Doug
