Elect. Ignition
I accidentally, cut off the coil mounting bolt holes, on my conversion engine. It is a small home-lite the one Carr said is "one of the best" to convert. What is the best (lowest price) way to put on an elect. ignition. Or can it be converted to glow/ nitro?
Thanks for any help bobbdd
bobdd,
Jerry Howell sells a TIM 6 electronic ignition kit for about $41. This includes the circuit components, Hall sensor, and Model Electics coil. You will have to provide some misc. wire, a plug wire/boot, and 6v. battery. I used a shielded 14mm wire/boot from CH Ignitions. The whole package weighs 3.25oz and works fine. Since it is a fixed timing unit, I set mine at 25 BTDC and seems to run well.
You could do a search on here and come up with the address.
Good luck.
Doug
Good luck.
Doug
Hi,
Go here: http://www.rcuniverse.com/showthread...l&pagenumber=3 , and scroll down to my post on dwell.
Hope this helps,
Good luck and take care,
AV8TORR
Hope this helps,
AV8TORR
Hi
yes I can see that it would only what I am interested in is how mechanicly were you able to get the required ddwel .. were you able to this with one magnet and a small dia pickup or just what thanks les
Hay
Thanks a million I got one of those ing. and have misplaced everthing but the coil I guess it's another 15 thanks to old age and a failing memory. Oh yes about what is your upper rpm range. Thanks again Les
