RCU Forums - View Single Post - DRAGON RETRACT PROBLEMS
Old 09-26-2010 | 07:21 PM
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: DRAGON RETRACT PROBLEMS
Jim,
There is a very simple solution I discovered years ago when I came across the same issue on some Asian gear. Just drill the side of the trunion and tap for a setscrew. 4/40 or 6/32 is fine. Put the strut in the retract but dont tighten the clamp bolt. Center up the wheel with the normal tad of toe in then lightly snug up the set screw against the strut. Now tighten up the clamp bolt and your good to go. The setscrew will take up any tolerance issue with the trunion plus give additional restraint against rotation.
