RCU Forums - View Single Post - making your own extensions
Old 09-27-2010 | 09:18 AM
goirish's Avatar
goirish
Default RE: making your own extensions
ORIGINAL: JohnBuckner
I would rather eliminate as many plugs as possible for reliability reasons so use very few extentions.
For ailerons for example I cut the new servos lead in half and splice in new heavy duty twisted servo wire to the exact length needed and no more. Its a very simple solderjob and its a technique that will serve you well in the hobby worth learning.
John
So John if you use that servo in another application and the new lead is now too long, what do you do? Maybe I am the only one that switches servos from one plane to another.
