RCU Forums - View Single Post - making your own extensions
Old 09-27-2010 | 01:37 PM
Gray Beard
My Feedback: (-1)
Default RE: making your own extensions
Here you go Gene, one stock servo wire and one I made up for a plane by soldering in a splice to get one the length I need. If I use this servo in a smaller plane {or bigger} I can just cut the shrink wrap off and unsolder the wires then do what needs doing. I solder on all three wires and shrink wrap then I use a piece of bigger shring wrap over the splice. These also slide through the lead tubes easier and I never have to pull and clean them. It takes me about 15 minutes to do a splice with 6 solder joints.
ID:	1507679   Click image for larger version
