How do you tweak in an Ultimate for 3D?
You need big throws. an oversized engine and a fine pich prop.
Ive wrote this on anouter forum someware ill copy it into here. It was areply to a guys question:
I dont no of any manual.
but.......... for 3d you need at least 50 degrees on elv., not so much on the ail. and as much as pos on the rudder.
I dont fly with rates, i fly with a high amount of expo so small stick movments make small deflections and big stick movments make big movments!
I have a flip 3D on futaba radio (reverce expo for jr, + 30 on JR is the same as -30 on futaba) and this is my setup:
Ail. 100%atv
100% rates hi/lo
-70%expo hi/lo
Elv: 100%atv
100%rates hi/lo
-100% expo hi/lo
Rudd: 100%atv
100%rates
-100%expo HUGE rudder is mega sensitive
Elv-flap mix: 100%
Airbrakes: Elv: 0%
flaps: up 80%
Bet beware. ive been flyin 3D for a while now. DO NOT fly with the throttle wide open. if you do, say bye bye to the wings!!! and stick to the instruktions for throws. DO NOT ventre over this for the start. you WILL regrett it. the os should be fine. if not buy a YS 63, West 50T1 or a satio 71.
Hope this is some help to you
Ian
