DX7 Binding Problem
I am having trouble binding my DX7 to my AR 7000.<p class="MsoNormal">I have the binding plug in the bind socket and the battery connected through a switch to an open port.<span style="mso-spacerun:yes"> </span>When I turned the power to the receiver on and the light blinks quickly as I expected.</p><p class="MsoNormal">Then holding the binding switched on the back of the transmitter down, I turned the DX7 on.<span style="mso-spacerun:yes"> </span>All the lights on both the receiver and the transmitter blank and then stop blinking just as the instructions say they should.</p><p class="MsoNormal">At that point I removed the binding plug.<span style="mso-spacerun:yes"> </span>All the controls work perfectly. When I turned the transmitter off and back on everything still worked fine.</p><p class="MsoNormal">The problem came when I turned the receiver off.<span style="mso-spacerun:yes"> </span>When I power it backed on, the lights on, the receiver lights start blinking quickly again as if it is expecting to go through the binding process all over.<span style="mso-spacerun:yes"> </span>So, it appears the receiver is not remembering that it has been bound.</p><p class="MsoNormal">Now for the crazy part-I have two AR 7000 receivers and both of them behave exactly the same way which seems to point to the transmitter.</p><p class="MsoNormal">Can anyone help?</p><p class="MsoNormal">Thanks<span style="mso-spacerun:yes"> </span>Rich</p>
