RCU Forums - View Single Post - Model Data Convertor
Old 09-28-2010 | 10:47 AM
Bax
Default RE: Model Data Convertor
Is it possible that your friend's model memory is actually set up as motor-glider? There should not be such a change...but the FX-40 is a little bit different from the 14MZ. The software is different, so it could be something in the software.
If your model gets the correct setups, even though the model type is motor-glider instead of glider, I wouldn't be too concerned.
