RCU Forums - View Single Post - Ram 750 setup problem
Old 09-28-2010 | 03:08 PM
henschel
My Feedback: (47)
Default Ram 750 setup problem
Having a problem setting transmitter throttle settings to ECU. Trim settings don't seem to be getting set properly to ECU. Can't get past EGT light. This is an older airstart turbine. Ser#750059. My manual is for ser#750388F. Here is what manual says.
A. High throttle setup:
1. Turn on transmitter
2. Push and hold "set" button while turning the Rx power ON. Turn on transmitter
The Start box display reads:
Setup throttle
High >xxxx
At this time the "Ign" LED flashes
3. Release the SET button.
4. Move throttle stick and Trim lever to Full throttle'
5. Adjust the ATV(if required) until the "Ign" LED stops.
6. Push the "SET" button to memorize.
B. Low throttle setup'
The start box display reads:
Setup throttle
Low>xxxx
At this time the "EGT" LED is flashing.
1. Move the throttle stick to LOW throttle, High trim.
2. Adjust the ATV (if required) until the "EGT" LED stops.
3. Push the "SET" button to memorize.
C. Idle cutoff setup:
Setup throttle
SHUTDN >xxxx
At this time the "CP" LED is flashing
1. With throttle stick to Low throttle,Mid trim
2. Adjust the ATV (if required) until the "EGT" LED stops flashing.
ECU is now programmed. Turn the Rx power off.
Just can't seem to program right. Maybe I have the wrong manual? Any help would be appreciated. This turbine is new and has never been run.
