RCU Forums - View Single Post - Ram 750 setup problem
Old 09-28-2010 | 03:42 PM
Ravivos's Avatar
Ravivos
Default RE: Ram 750 setup problem
reverse your throttle channel on your transmitter.
if the throttle is not reversed (i.e idle command has a higher pulse width than full throttle), the ECU cant calculate the dynamic range between the two values.
