RCU Forums - View Single Post - Scaled up Tower Fun 51
Old 09-29-2010 | 04:26 AM
bps's Avatar
bps
Default RE: Scaled up Tower Fun 51
Flew the 51 last evening. The Saito .82 4S is plenty of power and pulls this plane straight up. Gear reatract function just adds to the fun. I do have one big problem though and it will need to be repaired this winter, ending the flying season for this bird. The joint where the fuse meets the wing developed a crack. I think this is mainly due to the vibration that the Saito creates, it is a bunch. Spinner, prop ballanced and rechecked. My fix will be to add 1/4" ply to both sides of the fuse back to the rear edge of the wing. That should stiffin things up considerably.
I am also considering moving the motor back an inch to help with ballance. I did have to add a touch of weight to the tail. With the extra ply on the nose I will need to add more tail weight. Looks like about an inch would do it.
The last modification I plan is to add a tube on the bottom of the fuse to carry the crackcase drain and exhaust. The Saito creates a bunch of mess along with all that power.
I plan on fireing the engineer on this project as soon as I complete these mods! He gets fired a lot.
