Hello there, im all new to rc hobbies, and i have some questions. Some may seem stupied, but I haven never been in contact with this hobbie before,and noone to ask for guidiance. Well anyway....
You start your car with a glower... how does it work? Do you just put the glower on the <span class="short_text" id="result_box"><span title="" style="background-color: rgb(255, 255, 255); color: rgb(0, 0, 0);">glow</span></span><span class="short_text" id="result_box"><span title="" style="background-color: rgb(255, 255, 255); color: rgb(0, 0, 0);">pin for a few minutes? Do every glower work for every </span></span><span class="short_text" id="result_box"><span title="" style="background-color: rgb(255, 255, 255); color: rgb(0, 0, 0);">pin?
How do you turn of the car, is there a on/off switch on the radio?
Do you use only a batterie on the reciver, or also on gas/brake and steering servo?
Do some starterboxes work for specific cars only?
Why do you use those instead of standard batteries?
http://shop.strato.de/epages/6245467...es/Akkus/Lipos
</span></span>
